Saltar al contenido principal
LG Incite Motherboard Replacement
Qué necesitas
  1. LG Incite Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Motherboard Replacement: paso 2, imagen 1 de 1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Motherboard Replacement: paso 3, imagen 1 de 1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Motherboard Replacement, Back Panel: paso 4, imagen 1 de 1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Motherboard Replacement: paso 5, imagen 1 de 1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Motherboard Replacement: paso 6, imagen 1 de 1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
  7. LG Incite Motherboard Replacement, Motherboard: paso 7, imagen 1 de 3 LG Incite Motherboard Replacement, Motherboard: paso 7, imagen 2 de 3 LG Incite Motherboard Replacement, Motherboard: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
    • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
    • Repeat this for the white tab on the opposite side of the phone.
    • This tab also has two plastic bases adhering it to the edge of the phone.
  8. LG Incite Motherboard Replacement: paso 8, imagen 1 de 1
    • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
    • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
  9. LG Incite Motherboard Replacement: paso 9, imagen 1 de 2 LG Incite Motherboard Replacement: paso 9, imagen 2 de 2
    • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
    • Do not remove the tab completely, it should still be connected to the phone.
  10. LG Incite Motherboard Replacement: paso 10, imagen 1 de 1
    • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
    • Lift the motherboard and slide it towards you by hand to free it from the phone.
    • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
Conclusión
Kimberly Kha
Miembro Desde 04/16/13
163 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 2-18, Maness Spring 2013 Miembro de Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 783
