Introducción
If your phone's motherboard is faulty, this guide will show you how to safely replace it.
Flip your phone over and locate the battery cover.
  • Flip your phone over and locate the battery cover.
Agregar Comentario
Slide the cover downward to reveal the battery below.
  • Slide the cover downward to reveal the battery below.
Agregar Comentario
  • Place the plastic opening tool in the divet in the bottom left-hand corner.
  • Pry the battery upward to remove it.
Agregar Comentario
  • Unscrew the four 4.5mm screws using the Philips #00 screw driver.
Agregar Comentario
  • Wedge the plastic opening tool between the screen and the case.
  • Gently move the tool along the edge to loosen the screen from the casing. Repeat this for the entire outer edge of the screen.
    • You should not completely separate the screen from the case in this step.
Agregar Comentario
  • Flip your phone over to the battery side.
  • Push the plastic opening tool into the lower seam between the frame and front cover to separate the back panel.
    • Push the scroll wheel, located in the upper left corner, in while lifting the back cover off to prevent breaking it.
  • The volume, lock, and camera buttons are loose so don't lose them.
Agregar Comentario
  • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
    • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
  • Repeat this for the white tab on the opposite side of the phone.
    • This tab also has two plastic bases adhering it to the edge of the phone.
Agregar Comentario
  • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
  • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
Agregar Comentario
  • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
  • Do not remove the tab completely, it should still be connected to the phone.
Agregar Comentario
  • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
  • Lift the motherboard and slide it towards you by hand to free it from the phone.
  • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
Agregar Comentario
Conclusión
Kimberly Kha
Miembro Desde 16/04/13
163 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 2-18, Maness Spring 2013 Miembro de Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 630
