Introducción
This guide exists to act solely as a prerequisite to other replacement guides. These steps are necessary for replacing any of the components mentioned in later guides and are aggregated here to simplify the guide making process.
Please note that this guide will require the removal of the phone's battery, and while this is a trivial task with this particular model, if your battery is swollen and stuck then prying at is could potentially cause it to rupture and explode.
Please power off your device and take it to a repair professional or someone else trained in safely disposing of the malfunctioning battery. As a general rule of thumb, always turn off any device you are working on.
Qué necesitas
Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
