Saltar al contenido principal
LG GW910 Keyboard Replacement
Qué necesitas
  1. LG GW910 Keyboard Replacement, Motherboard: paso 1, imagen 1 de 2 LG GW910 Keyboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Keyboard Replacement: paso 2, imagen 1 de 2 LG GW910 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove six 3mm PH000 screws.
  4. LG GW910 Keyboard Replacement: paso 4, imagen 1 de 3 LG GW910 Keyboard Replacement: paso 4, imagen 2 de 3 LG GW910 Keyboard Replacement: paso 4, imagen 3 de 3
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Keyboard Replacement: paso 5, imagen 1 de 1
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Keyboard Replacement: paso 6, imagen 1 de 1
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Keyboard Replacement: paso 7, imagen 1 de 3 LG GW910 Keyboard Replacement: paso 7, imagen 2 de 3 LG GW910 Keyboard Replacement: paso 7, imagen 3 de 3
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
  8. LG GW910 Keyboard Replacement, Keyboard: paso 8, imagen 1 de 1
    • Remove six 1mm PH00 screws.
  9. LG GW910 Keyboard Replacement: paso 9, imagen 1 de 2 LG GW910 Keyboard Replacement: paso 9, imagen 2 de 2
    • Peel off the tape to expose the hidden screw.
    • Replacement tape might be needed.
  10. LG GW910 Keyboard Replacement: paso 10, imagen 1 de 2 LG GW910 Keyboard Replacement: paso 10, imagen 2 de 2
    • Pry off the board from the side using the metal spudger tool.
    • Disconnect the antenna.
  11. LG GW910 Keyboard Replacement: paso 11, imagen 1 de 1
    • Remove the keyboard assembly from the main frame.
    • The keyboard cover is loose.
    • Make sure to pull the small keyboard battery out with the whole assembly
Conclusión
Una persona más ha completado esta guía.
Jonas Ke
Miembro Desde 11/06/18
492 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G6, Hovde Fall 2018 Miembro de IUPUI, Team S1-G6, Hovde Fall 2018
IUPUI-HOVDE-F18S1G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 104
