Saltar al contenido principal
LG GS170 Battery Replacement
  1. LG GS170 Battery Replacement, Back Cover: paso 1, imagen 1 de 3 LG GS170 Battery Replacement, Back Cover: paso 1, imagen 2 de 3 LG GS170 Battery Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn off the the cell phone.
    • Locate the the arrow at the top of the back cover.
    • Slide the cover downward until the cover comes off.
  2. LG GS170 Battery Replacement, Battery: paso 2, imagen 1 de 3 LG GS170 Battery Replacement, Battery: paso 2, imagen 2 de 3 LG GS170 Battery Replacement, Battery: paso 2, imagen 3 de 3
    • Completely remove the back cover, and the battery should be visible.
    • Locate the gap at the bottom right.
    • Use your thumb to pop out the battery.
  3. LG GS170 Battery Replacement: paso 3, imagen 1 de 1
    • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
Conclusión
Una persona más ha completado esta guía.
Minna
Miembro Desde 10/08/14
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-25, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-25, Donnelly Fall 2014
USFT-DONNELLY-F14S1G25
1 Miembro
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 449
