Saltar al contenido principal
LG G6 SIM Card Reader Replacement
Qué necesitas
    • Insert wisdom here.
Conclusión
MovilOne
Miembro Desde 06/17/14
2,480 Reputación
14 Guías creadas
3 comentarios
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - Contestar
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - Contestar
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 4,295
