Saltar al contenido principal
LG G3 Vigor Motherboard Replacement
Qué necesitas
  1. LG G3 Vigor Motherboard Replacement, Rear Case: paso 1, imagen 1 de 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Motherboard Replacement: paso 2, imagen 1 de 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Motherboard Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Motherboard Replacement, Midframe: paso 4, imagen 1 de 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Motherboard Replacement: paso 5, imagen 1 de 3 LG G3 Vigor Motherboard Replacement: paso 5, imagen 2 de 3 LG G3 Vigor Motherboard Replacement: paso 5, imagen 3 de 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Motherboard Replacement, Rear Facing Camera: paso 6, imagen 1 de 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Motherboard Replacement, Front Facing Camera: paso 7, imagen 1 de 2 LG G3 Vigor Motherboard Replacement, Front Facing Camera: paso 7, imagen 2 de 2
    • Remove the front camera.
  8. LG G3 Vigor Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Motherboard Replacement: paso 9, imagen 1 de 2 LG G3 Vigor Motherboard Replacement: paso 9, imagen 2 de 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
Conclusión
8 personas más completaron esta guía.
Jared Stickl
Miembro Desde 02/08/16
407 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 12-5, Eyestone Spring 2016 Miembro de USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 2,003
