Saltar al contenido principal
Introducción
Use this guide to remove or replace a broken or worn-out screen assembly including the midframe in the LG G3 (D855).
This guide shows how to replace the whole screen assembly of the LG G3 including the midframe. All components such as the vibration motor, the cameras, and the earpiece speaker need to be transferred to the replacement part during the repair process. In case you want to replace the LCD without the frame you need to follow this guide.
  1. Power off your phone before beginning disassembly. Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. Lift the back cover to release the rest of the plastic clips and remove it. In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • Remove the back cover.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess. Lever the battery up until you can get a good grip.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
  4. Lift the battery out of its recess and remove it. Lift the battery out of its recess and remove it.
    • Lift the battery out of its recess and remove it.
  5. Remove the four Phillips #00 screws (4 mm length).
    • Remove the four Phillips #00 screws (4 mm length).
  6. Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover. Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly. Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. Remove the eight Phillips #00 screws (4 mm length).
    • Remove the eight Phillips #00 screws (4 mm length).
  9. Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard. Pry up the motherboard cover to open the plastic clamps which hold the cover in its place. The clamps can be a bit restive. In case you're having trouble to open them you can flip the opening pick a bit sideways to make the process easier.
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clamps which hold the cover in its place.
    • The clamps can be a bit restive. In case you're having trouble to open them you can flip the opening pick a bit sideways to make the process easier.
    • Work your way along the right edge of the motherboard cover and use the opening pick to pry it up.
  10. Get a good grip to the motherboard cover assembly and start to lift the right edge of it. The remaining plastic clamps should open during this process or can be unhinged easily by hand. Remove the motherboard assembly.
    • Get a good grip to the motherboard cover assembly and start to lift the right edge of it.
    • The remaining plastic clamps should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. Use a spudger to pry up and disconnect the display flex cable. Use a spudger to pry up and disconnect the display flex cable.
    • Use a spudger to pry up and disconnect the display flex cable.
  12. Use a spudger to pry up and disconnect the digitizer flex cable. Use a spudger to pry up and disconnect the digitizer flex cable.
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. Use a spudger to pry up and disconnect the rear camera flex cable. Use a spudger to pry up and disconnect the rear camera flex cable.
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. Use a spudger to pry up and disconnect the front camera flex cable. Use a spudger to pry up and disconnect the front camera flex cable.
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. Avoid to damage the flex cables you disconnected during the motherboard removal procedure. Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
    • Avoid to damage the flex cables you disconnected during the motherboard removal procedure.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways. Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. Get a grip to the upper part of the motherboard during the removal procedure to avoid breakage. Carefully remove the motherboard.
    • Get a grip to the upper part of the motherboard during the removal procedure to avoid breakage.
    • Carefully remove the motherboard.
  18. Apply a heated iOpener to the top end of the screen to loosen the adhesive underneath.
  19. During the removal of the earpiece speaker, remove it together with the foam gasket underneath. Use a pair of tweezers to remove the earpiece speaker.
    • During the removal of the earpiece speaker, remove it together with the foam gasket underneath.
    • Use a pair of tweezers to remove the earpiece speaker.
  20. Use a pair of tweezers to remove the front camera. Use a pair of tweezers to remove the front camera.
    • Use a pair of tweezers to remove the front camera.
  21. If you're having trouble removing the rear camera or the vibration motor, reapply the heated iOpener to loosen the adhesive underneath. Use a pair of tweezers to remove the rear camera.
    • If you're having trouble removing the rear camera or the vibration motor, reapply the heated iOpener to loosen the adhesive underneath.
    • Use a pair of tweezers to remove the rear camera.
  22. Insert one half of a pair of tweezers under the vibration motor and pry it up. Use the tweezers to remove the vibration motor. Use the tweezers to remove the vibration motor.
    • Insert one half of a pair of tweezers under the vibration motor and pry it up.
    • Use the tweezers to remove the vibration motor.
  23. Apply a heated iOpener to the bottom end of the screen to loosen the adhesive underneath.
  24. Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers. Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers. Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
    • Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
  25. Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly. Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly. Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
    • Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
  26. Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
Conclusión
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
If possible turn on your phone and test your replacement part before reassembling your phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
119 personas más completaron esta guía.
Equipo
iFixit Miembro de iFixit
Community
108 Miembros
9,532 Guías creadas
Ok so after I did all this my screen is black and so I ordered a second screen and also nothing the phone works great and makes noises also touch responds but nothing on lcd just black can you help me with this also if I take battery out and plug up charger it shows a battery warning on lcd so clearly it works
cabinlife27030 - Contestar
Has it sustained any water damage?
Josiah Leas -
Did you get it working i have the same issue? the picture displays with the original screen but not with the new one. i have tried 3 different screens and get the same on all of them. i even tried updating to the latest software but only get a black screen, no picture.
When i have had this on iphones i just so a reset by holding down the buttons and the screen starts to work.
Please someone help
Matt -
Same here! I also findout that lcd still works, if you get some flashlight on screen in a dark room, you will see that only backlight not working when battery plugged. I tried to baking it but it still didn't worked. It's obvious that backlight could properly operate as it works when you take off the battery. I'm looking for solutions, if I find any, will wrote it here.
tufekcisencer -
Did someone find a solution to this? I also replaced my screen and it keeps black solid when I turn it on, even with the touch working properly.
fsnaderfb -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 68
Ultimos 30 días: 267
Todo El Tiempo: 242,962
