Introducción
This guide will show you how to replace a damaged digitizer and LCD on your LG G3.
This part is only the fused display and digitizer and does not contain the support frame. If your replacement part includes the frame, follow this shorter, less complicated screen replacement guide.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Remove the metal tape to reveal the ribbon cables connected to the screen
The metal tape is stuck on there pretty well. Get the plastic opening tool under the right-hand side and corners and slowly work your way to getting it off
Be careful when removing the metal tape. We can reuse it after we replace the screen
Take something thin, such as a knife, and wedge it between the screen and the body of the phone
One you have created some space, wedge your plastic opening tool into the space and remove the knife
Move your plastic opening tool up and down the side of the phone while lightly pulling up. Repeat this for all sides until the screen comes out
3 personas más completaron esta guía.
