Saltar al contenido principal
LG G2 mini LTE Headphone Jack Replacement
Qué necesitas
  1. LG G2 mini LTE Headphone Jack Replacement, Remove the Battery Cover: paso 1, imagen 1 de 1
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. LG G2 mini LTE Headphone Jack Replacement, Remove the Battery: paso 2, imagen 1 de 1
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE Headphone Jack Replacement, Unscrew the Motherboard Cover: paso 3, imagen 1 de 2 LG G2 mini LTE Headphone Jack Replacement, Unscrew the Motherboard Cover: paso 3, imagen 2 de 2
    • Locate 10 screws and remove each one using a screw driver.
  4. LG G2 mini LTE Headphone Jack Replacement, Remove the Motherboard Cover: paso 4, imagen 1 de 1
    • Use a plastic spudger tool to pry away the cover by placing it between the cover and the screen bezel.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE Headphone Jack Replacement, Remove Headphone jack: paso 5, imagen 1 de 3 LG G2 mini LTE Headphone Jack Replacement, Remove Headphone jack: paso 5, imagen 2 de 3 LG G2 mini LTE Headphone Jack Replacement, Remove Headphone jack: paso 5, imagen 3 de 3
    • Locate the headphone jack.
    • Use spudger tool to pry the headphone jack from the bottom.
    • Use fingers to fully remove the headphone jack.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Miembro de UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,731
