Saltar al contenido principal
LG G Watch R Battery Housing
Qué necesitas
  1. LG G Watch R Battery Housing, Back Case: paso 1, imagen 1 de 2 LG G Watch R Battery Housing, Back Case: paso 1, imagen 2 de 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Housing: paso 2, imagen 1 de 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Housing: paso 3, imagen 1 de 1
    • Remove the back case.
  4. LG G Watch R Battery Housing, Motherboard: paso 4, imagen 1 de 2 LG G Watch R Battery Housing, Motherboard: paso 4, imagen 2 de 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Housing: paso 5, imagen 1 de 2 LG G Watch R Battery Housing: paso 5, imagen 2 de 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Housing: paso 6, imagen 1 de 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Housing, Battery Replacement: paso 7, imagen 1 de 1
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
  8. LG G Watch R Battery Housing, Battery Housing Replacement: paso 8, imagen 1 de 2 LG G Watch R Battery Housing, Battery Housing Replacement: paso 8, imagen 2 de 2
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
Conclusión
2 personas más completaron esta guía.
Westley Courchene
Miembro Desde 01/13/15
3,410 Reputación
14 Guías creadas
Equipo
USF Tampa, Team 1-1, Remmell Fall 2015 Miembro de USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Miembros
14 Guías creadas
Un comentario
Hi there, do you know where can i buy the battery housing? Thank you..
Eugene Kang - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,594
