Saltar al contenido principal
LG G Watch Gasket Replacement
Qué necesitas
  1. LG G Watch Gasket Replacement, Wristband: paso 1, imagen 1 de 1
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Gasket Replacement: paso 2, imagen 1 de 2 LG G Watch Gasket Replacement: paso 2, imagen 2 de 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Gasket Replacement, Rear Case: paso 3, imagen 1 de 1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Gasket Replacement: paso 4, imagen 1 de 2 LG G Watch Gasket Replacement: paso 4, imagen 2 de 2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Gasket Replacement, Gasket: paso 5, imagen 1 de 1
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
Conclusión
Una persona más ha completado esta guía.
Deja Miller
Miembro Desde 10/14/14
462 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-5, Blackwell Fall 2014 Miembro de USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 636
