Saltar al contenido principal
LG G Vista Screen Replacement
Qué necesitas
  1. LG G Vista Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the device is powered off.
  2. LG G Vista Screen Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Screen Replacement: paso 3, imagen 1 de 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Screen Replacement, Screen: paso 4, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove all eleven 3.0 mm screws from around the perimeter of the phone.
  5. LG G Vista Screen Replacement: paso 5, imagen 1 de 1
    • Use a plastic spudger or opening tool and run it along the seam of the upper cover.
    • Carefully remove the cover from the device.
  6. LG G Vista Screen Replacement: paso 6, imagen 1 de 1
    • Use the same method to pry off the hard shell covering at the bottom.
  7. LG G Vista Screen Replacement: paso 7, imagen 1 de 1
    • Remove the two 1 mm Phillips #000 screws.
  8. LG G Vista Screen Replacement: paso 8, imagen 1 de 2 LG G Vista Screen Replacement: paso 8, imagen 2 de 2
    • Gently using tweezers, disconnect the connector that is on the bottom right.
  9. LG G Vista Screen Replacement: paso 9, imagen 1 de 2 LG G Vista Screen Replacement: paso 9, imagen 2 de 2
    • Gently unplug the antenna wires on the bottom left and right sides of the device.
  10. LG G Vista Screen Replacement: paso 10, imagen 1 de 1
    • With your plastic opening tool, gently lift up the bottom edge of the exposed charging port, sliding along the edge until it lifts out.
  11. LG G Vista Screen Replacement: paso 11, imagen 1 de 1
    • Using tweezers, unplug the four connectors.
  12. LG G Vista Screen Replacement: paso 12, imagen 1 de 2 LG G Vista Screen Replacement: paso 12, imagen 2 de 2
    • Remove the antenna wires on both sides of the device.
  13. LG G Vista Screen Replacement: paso 13, imagen 1 de 2 LG G Vista Screen Replacement: paso 13, imagen 2 de 2
    • Carefully lift out the back camera from the device.
    • Lift out the headphone jack in the upper right side of the device.
  14. LG G Vista Screen Replacement: paso 14, imagen 1 de 1
    • Remove the motherboard from the phone.
  15. LG G Vista Screen Replacement: paso 15, imagen 1 de 1
    • Remove the vibration motor from the device.
    • You will be left with the entire display assembly of the device.
Conclusión
To reassemble your device, follow these steps in reverse order.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 729
