Saltar al contenido principal
LG G Vista Motherboard Replacement
Qué necesitas
  1. LG G Vista Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the device is powered off.
  2. LG G Vista Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Motherboard Replacement: paso 3, imagen 1 de 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Motherboard Replacement, Motherboard: paso 4, imagen 1 de 1
    • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
  5. LG G Vista Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the hard shell covering the motherboard.
  6. LG G Vista Motherboard Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
  7. LG G Vista Motherboard Replacement: paso 7, imagen 1 de 2 LG G Vista Motherboard Replacement: paso 7, imagen 2 de 2
    • Use the tweezers to remove the four connectors as well as the back camera.
    • Be careful not to directly touch the camera lenses.
  8. LG G Vista Motherboard Replacement: paso 8, imagen 1 de 1
    • Lift up and remove the motherboard from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 480
