Saltar al contenido principal
LG G Pad X 8.0 Battery Replacement
Qué necesitas
  1. LG G Pad X 8.0 Battery Replacement, Removing Backplate: paso 1, imagen 1 de 1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: paso 2, imagen 1 de 2 LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: paso 2, imagen 2 de 2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: paso 3, imagen 1 de 3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: paso 3, imagen 2 de 3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: paso 3, imagen 3 de 3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Battery Replacement, Removing the Battery: paso 4, imagen 1 de 1
    • Remove the battery by pulling up gently.
Conclusión
17 personas más completaron esta guía.
[deleted]
Miembro Desde 05/18/17
1,146 Reputación
3 Guías creadas
10 comentarios
I was going to do this to fix my son's tablet and then I looked up the cost of a replacement battery on eBay. Almost $100! Do you have a good source for a new battery?
poeticpyr07 - Contestar
Unfortunately, no, there does not seem to be a good part supplier for the G Pad X 8.0. As you mention, the best I see is eBay at $82.
[deleted] -
2 years on they're $14
Carlos Mendonca -
I have researched this battery, the LG BL T-20. I found one that is 4800 MaH. The LG Gpad X8.0 has the same battery that is 4650 MaH. If I order the 4800 MaH, will it work?
luvgod10 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 26
Todo El Tiempo: 14,936
