Saltar al contenido principal
LG G Pad F 7.0 Speaker Replacement
Qué necesitas
  1. LG G Pad F 7.0 Speaker Replacement, Speaker: paso 1, imagen 1 de 2 LG G Pad F 7.0 Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Speaker Replacement: paso 2, imagen 1 de 2 LG G Pad F 7.0 Speaker Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Speaker Replacement: paso 3, imagen 1 de 3 LG G Pad F 7.0 Speaker Replacement: paso 3, imagen 2 de 3 LG G Pad F 7.0 Speaker Replacement: paso 3, imagen 3 de 3
    • Locate the LG G Pad F 7.0 speaker
    • Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
    • Remove old speaker and replace with a new one
Conclusión
2 personas más completaron esta guía.
Jose Hurtado
Miembro Desde 01/25/17
329 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-5, Banghart Winter 2017 Miembro de Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 181
