Saltar al contenido principal
LG G Pad F 7.0 Charging Port Replacement
Qué necesitas
  1. LG G Pad F 7.0 Charging Port  Replacement, Charging Port: paso 1, imagen 1 de 2 LG G Pad F 7.0 Charging Port  Replacement, Charging Port: paso 1, imagen 2 de 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Charging Port  Replacement: paso 2, imagen 1 de 2 LG G Pad F 7.0 Charging Port  Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Charging Port  Replacement: paso 3, imagen 1 de 1
    • Locate the top of the large orange ribbon cable.
    • Pry it off with the plastic opening tool as shown in the image.
  4. LG G Pad F 7.0 Charging Port  Replacement: paso 4, imagen 1 de 2 LG G Pad F 7.0 Charging Port  Replacement: paso 4, imagen 2 de 2
    • Remove the gyroscope (the blue rectangular cube) located near the bottom of the device with the plastic opening tool as shown in the image.
    • Remove the speaker located in the bottom right corner of the device with the plastic opening tool as shown in the image.
  5. LG G Pad F 7.0 Charging Port  Replacement: paso 5, imagen 1 de 2 LG G Pad F 7.0 Charging Port  Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two screws located on the charging port as seen in the image using the Phillips screwdriver.
    • Using the tweezers, remove the orange ribbon cable along with the charging port.
Conclusión
7 personas más completaron esta guía.
Erik
Miembro Desde 01/25/17
293 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-5, Banghart Winter 2017 Miembro de Cal Poly, Team 8-5, Banghart Winter 2017
CPSU-BANGHART-W17S8G5
3 Miembros
10 Guías creadas
4 comentarios
Good work, Pictures are clear and easy to follow
Jonah Basl - Contestar
Just a minor item. On step 4 it tells you to remove the gyroscope, then remove the speaker. On on the unit I worked in you had to remove the speaker so you could get remove the gyroscope. I was working on the 8.0 instead of the 7.0 model, so perhaps that accounted for the difference.
Alan Siebens - Contestar
Where do you buy the new charging port you need to put in? It's like gold lined teeth top and bottom.
Stands For Jesus - Contestar
Also on his LG can we turn it into a prepaid monthly service if we get a at&t sim card kit or something similar?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 4,061
