Saltar al contenido principal
LG G Pad 8.3 Volume Control Buttons Replacement
Qué necesitas
  1. LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: paso 1, imagen 1 de 2 LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: paso 1, imagen 2 de 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Volume Control Buttons Replacement: paso 2, imagen 1 de 3 LG G Pad 8.3 Volume Control Buttons Replacement: paso 2, imagen 2 de 3 LG G Pad 8.3 Volume Control Buttons Replacement: paso 2, imagen 3 de 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Volume Control Buttons Replacement: paso 3, imagen 1 de 2 LG G Pad 8.3 Volume Control Buttons Replacement: paso 3, imagen 2 de 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: paso 4, imagen 1 de 2 LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: paso 4, imagen 2 de 2
    • With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side.
    • Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
Conclusión
Equipo
CSU Fullerton, Team 1-6, Bruce Fall 2015 Miembro de CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,072
