Saltar al contenido principal
LG G Pad 8.3 Rear Facing Camera Replacement
Qué necesitas
  1. LG G Pad 8.3 Rear Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement, Back Panel: paso 1, imagen 2 de 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Rear Facing Camera Replacement: paso 2, imagen 1 de 3 LG G Pad 8.3 Rear Facing Camera Replacement: paso 2, imagen 2 de 3 LG G Pad 8.3 Rear Facing Camera Replacement: paso 2, imagen 3 de 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Rear Facing Camera Replacement: paso 3, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement: paso 3, imagen 2 de 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Rear Facing Camera Replacement, Speaker: paso 4, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement, Speaker: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Rear Facing Camera Replacement: paso 5, imagen 1 de 1
    • Use your fingers to remove the speaker.
  6. LG G Pad 8.3 Rear Facing Camera Replacement, Battery: paso 6, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the 3mm Phillips #000 screws from the corners of the battery.
  7. LG G Pad 8.3 Rear Facing Camera Replacement: paso 7, imagen 1 de 3 LG G Pad 8.3 Rear Facing Camera Replacement: paso 7, imagen 2 de 3 LG G Pad 8.3 Rear Facing Camera Replacement: paso 7, imagen 3 de 3
    • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
    • The cable is attached with an adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  8. LG G Pad 8.3 Rear Facing Camera Replacement: paso 8, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement: paso 8, imagen 2 de 2
    • Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
    • Remove the ribbon cable from the device.
  9. LG G Pad 8.3 Rear Facing Camera Replacement: paso 9, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement: paso 9, imagen 2 de 2
    • Unhook the battery from the top of the device.
  10. LG G Pad 8.3 Rear Facing Camera Replacement, Motherboard: paso 10, imagen 1 de 1
    • Unhook the small yellow ribbon on top of the motherboard.
  11. LG G Pad 8.3 Rear Facing Camera Replacement: paso 11, imagen 1 de 1
    • Remove all the 3mm silver screws and the 2mm black screws on the motherboard and carefully lift it out of the device.
  12. LG G Pad 8.3 Rear Facing Camera Replacement: paso 12, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement: paso 12, imagen 2 de 2
    • Use a plastic opening tool to lift the motherboard out of the device.
  13. LG G Pad 8.3 Rear Facing Camera Replacement, Rear Facing Camera: paso 13, imagen 1 de 2 LG G Pad 8.3 Rear Facing Camera Replacement, Rear Facing Camera: paso 13, imagen 2 de 2
    • Use a plastic opening tool to remove the camera, which is attached with adhesive to the front of the tablet.
Conclusión
Equipo
CSU Fullerton, Team 1-6, Bruce Fall 2015 Miembro de CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 612
