Saltar al contenido principal
LG G Pad 8.3 4G Speakers Replacement
Qué necesitas
  1. LG G Pad 8.3 4G Speakers Replacement, Back Panel: paso 1, imagen 1 de 1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Speakers Replacement: paso 2, imagen 1 de 3 LG G Pad 8.3 4G Speakers Replacement: paso 2, imagen 2 de 3 LG G Pad 8.3 4G Speakers Replacement: paso 2, imagen 3 de 3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. LG G Pad 8.3 4G Speakers Replacement, Speakers: paso 3, imagen 1 de 2 LG G Pad 8.3 4G Speakers Replacement, Speakers: paso 3, imagen 2 de 2
    • Remove the 4 1.5 mm screws holding the speakers in place.
  4. LG G Pad 8.3 4G Speakers Replacement: paso 4, imagen 1 de 3 LG G Pad 8.3 4G Speakers Replacement: paso 4, imagen 2 de 3 LG G Pad 8.3 4G Speakers Replacement: paso 4, imagen 3 de 3
    • Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
    • This cable can be damaged easily.
  5. LG G Pad 8.3 4G Speakers Replacement: paso 5, imagen 1 de 1
    • Pull the cable back and out of the way of the speaker.
  6. LG G Pad 8.3 4G Speakers Replacement: paso 6, imagen 1 de 2 LG G Pad 8.3 4G Speakers Replacement: paso 6, imagen 2 de 2
    • Place the spudger in between the speaker and the device to pop the speaker out of place.
    • Pull the speaker out of the device.
Conclusión
Deja Morrow
Miembro Desde 09/18/18
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 145
