Saltar al contenido principal
LG G Pad 7.0 LTE Front Screen Replacement
Qué necesitas
  1. LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: paso 1, imagen 1 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: paso 1, imagen 2 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: paso 1, imagen 3 de 3
    • Remove the MicroSD Memory card, Sim Card, and the metal Sim Card Holder.
    • Put them off to the side for reassembly.
    • Now you can slowly use a plastic opening tool to go around the edge of the tablet to slowly pry upward.
  2. LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: paso 2, imagen 1 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: paso 2, imagen 2 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: paso 2, imagen 3 de 3
    • Now that we have the back cover and can remove the orange port strip.
    • Use the spudger to gently remove the strip by pushing upward slowly.
  3. LG G Pad 7.0 LTE Front Screen Replacement, Disconnect the battery: paso 3, imagen 1 de 2 LG G Pad 7.0 LTE Front Screen Replacement, Disconnect the battery: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • To disconnect the battery you are going to unplug the cables.
    • Use the tweezers to gently hold the cables and slowly push upward to detach it.
    • Don't be too rough and pinch the cables with the tweezers. Take your time and slowly detach.
  4. LG G Pad 7.0 LTE Front Screen Replacement, Unscrew the motherboard: paso 4, imagen 1 de 1
    • Remove the 7 black screws on the motherboard.
    • Put them to the side for reassembly.
  5. LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: paso 5, imagen 1 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: paso 5, imagen 2 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: paso 5, imagen 3 de 3
    • Detach the black tag in the middle of the motherboard. This is the main camera connection.
    • Locate the next camera connection at the top of the motherboard. Disconnect this black tag for your front camera.
    • Now you are able to remove the motherboard from the tablet.
  6. LG G Pad 7.0 LTE Front Screen Replacement, Detach main camera: paso 6, imagen 1 de 2 LG G Pad 7.0 LTE Front Screen Replacement, Detach main camera: paso 6, imagen 2 de 2
    • Now that the motherboard is removed, you can now access the main camera for removal. Gently use the tweezers to do this.
    • Put to the side for reassembly.
  7. LG G Pad 7.0 LTE Front Screen Replacement, Remove front speaker: paso 7, imagen 1 de 2 LG G Pad 7.0 LTE Front Screen Replacement, Remove front speaker: paso 7, imagen 2 de 2
    • Using the Phillips screwdriver, remove the screw and put aside for reassembly.
  8. LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: paso 8, imagen 1 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: paso 8, imagen 2 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: paso 8, imagen 3 de 3
    • Two screws are holding the metal plate down. Remove the screws and put aside.
    • Use the tweezers to remove the tape to show the connection.
    • Use the spudger to push up and remove the connection.
    • Use the tweezers to completely remove charging port from tablet. Put aside for reassembly.
  9. LG G Pad 7.0 LTE Front Screen Replacement, Remove battery: paso 9, imagen 1 de 2 LG G Pad 7.0 LTE Front Screen Replacement, Remove battery: paso 9, imagen 2 de 2
    • To remove the battery, use the spudger or the Jimmy tool to slowly work your way around the battery.
    • It is being held on by strips of tape so be patient with it. Work it a little bit at a time to remove the battery from the tablet.
    • Put it aside for reassembly.
  10. LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: paso 10, imagen 1 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: paso 10, imagen 2 de 3 LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: paso 10, imagen 3 de 3
    • Apply a heat gun or iOpener to front of screen to allow it to warm up the glue.
    • Use opening tool and work your way around the front of the screen. You may have to alternate applying the heat and prying to get it loose enough to separate.
    • Be careful not overdo the heat. Use a low temperature and take your time to separate the screen.
    • Clean the black backing off of any glass still sticking to it. Mine had a lot so I had to scrape for awhile to get all the little pieces off to have a clean surface to apply the new replacement screen.
    • Apply new screen to black backing.
Conclusión
To reassemble your device, follow these instructions in reverse order. You will need new adhesive to apply upon reassembly.
**The time estimate is put at an hour but depending on how much broken glass you are dealing with and having to scrap off old adhesive glue - it could take longer so please have patience when dealing with glass to not injury yourself.
38 personas más completaron esta guía.
MissHeather
Miembro Desde 07/03/15
1,674 Reputación
2 Guías creadas
Equipo
Android Alliance Miembro de Android Alliance
Community
88 Miembros
701 Guías creadas
18 comentarios
Great help..........thanks
James Smith - Contestar
Good job but I have just 1 speaker out.
Do you mean you took one speaker out or the speaker is no longer functioning properly?
MissHeather -
Hello Ms. Heather I cannot access the motherboard, I am unable to remove the back cover. Pls help
kmonicaholloway - Contestar
Are you using a prying tool and going around the edges of the tablet to open it? What exactly is happening?
MissHeather -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 45
Todo El Tiempo: 39,966
