Saltar al contenido principal
LG G Pad 7.0 LTE Camera Replacement
Qué necesitas
  1. LG G Pad 7.0 LTE Camera Replacement, Removing the Back Cover: paso 1, imagen 1 de 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Camera Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Camera Replacement, Camera: paso 3, imagen 1 de 1
    • Disconnect camera ribbon cable by prying up on it with a plastic pry tool.
  4. LG G Pad 7.0 LTE Camera Replacement: paso 4, imagen 1 de 1
    • There is a light adhesive holding the camera in the device.
    • Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device (red marker).
  5. LG G Pad 7.0 LTE Camera Replacement: paso 5, imagen 1 de 1
    • Install the new camera into device by gently placing it in its corresponding place until it pops in.
Conclusión
Una persona más ha completado esta guía.
Fadi Bitar
Miembro Desde 09/26/16
880 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 14-6, Eyestone Fall 2016 Miembro de USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 308
