Saltar al contenido principal
LG G Pad 7.0 Battery Replacement
Qué necesitas
  1. LG G Pad 7.0 Battery Replacement, LG G-Pad 7.0: paso 1, imagen 1 de 1
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. LG G Pad 7.0 Battery Replacement, Jumping right into action: paso 2, imagen 1 de 2 LG G Pad 7.0 Battery Replacement, Jumping right into action: paso 2, imagen 2 de 2
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. LG G Pad 7.0 Battery Replacement, First Glimpse: paso 3, imagen 1 de 1
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. LG G Pad 7.0 Battery Replacement, A Look on the Inside: paso 4, imagen 1 de 1
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
  5. LG G Pad 7.0 Battery Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Grab your * Tweezers, the best tweezers you can get!
  6. LG G Pad 7.0 Battery Replacement, Charging Port Flex: paso 6, imagen 1 de 1
    Comprar
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  7. LG G Pad 7.0 Battery Replacement, Battery Connection: paso 7, imagen 1 de 1
    • Carefully lift the battery connector.
  8. LG G Pad 7.0 Battery Replacement, Removing the Battery: paso 8, imagen 1 de 1
    iSesamo Opening Tool
    $9.99
    Comprar
  9. LG G Pad 7.0 Battery Replacement, Disposal of old Battery: paso 9, imagen 1 de 1
    • After removing the faulty/dead battery, make sure you properly dispose it.
  10. LG G Pad 7.0 Battery Replacement, Don't Forget!: paso 10, imagen 1 de 2 LG G Pad 7.0 Battery Replacement, Don't Forget!: paso 10, imagen 2 de 2
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
Conclusión
2 personas más completaron esta guía.
GadgetERService
Miembro Desde 11/22/13
1,650 Reputación
2 Guías creadas
Equipo
Minnesota Repair Techs Miembro de Minnesota Repair Techs
Community
3 Miembros
2 Guías creadas
2 comentarios
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - Contestar
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 2,681
