Saltar al contenido principal
LG Front Load Washing Machine Main Board Replacement
Qué necesitas
  1. LG Front Load Washing Machine Main Board Replacement, Safety Precautions: paso 1, imagen 1 de 2 LG Front Load Washing Machine Main Board Replacement, Safety Precautions: paso 1, imagen 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: paso 2, imagen 1 de 3 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: paso 2, imagen 2 de 3 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: paso 2, imagen 3 de 3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Main Board Replacement, Remove the top panel: paso 3, imagen 1 de 2 LG Front Load Washing Machine Main Board Replacement, Remove the top panel: paso 3, imagen 2 de 2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Main Board Replacement: paso 4, imagen 1 de 2 LG Front Load Washing Machine Main Board Replacement: paso 4, imagen 2 de 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: paso 5, imagen 1 de 2 LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: paso 5, imagen 2 de 2
    • Depending on your device, your pressure sensor might have a wire harness. If so, disconnect each wire on the harness.
    • Disconnect the connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG Front Load Washing Machine Main Board Replacement: paso 6, imagen 1 de 2 LG Front Load Washing Machine Main Board Replacement: paso 6, imagen 2 de 2
    • Disconnect the hose from the pressure sensor.
  7. LG Front Load Washing Machine Main Board Replacement, Unfasten the pressure sensor: paso 7, imagen 1 de 1
    • Remove the screw(s) securing the pressure sensor.
  8. LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: paso 8, imagen 1 de 3 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: paso 8, imagen 2 de 3 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: paso 8, imagen 3 de 3
    • Unclip the pressure sensor from the chassis or other components.
  9. LG Front Load Washing Machine Main Board Replacement: paso 9, imagen 1 de 2 LG Front Load Washing Machine Main Board Replacement: paso 9, imagen 2 de 2
    • Lift the pressure sensor away chassis and remove it.
  10. LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: paso 10, imagen 1 de 3 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: paso 10, imagen 2 de 3 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: paso 10, imagen 3 de 3
    • Disconnect any cables or fasteners secured to the control panel cover.
    • Repeat this procedure for any bundled cables that keep the cover from opening.
  11. LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: paso 11, imagen 1 de 3 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: paso 11, imagen 2 de 3 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: paso 11, imagen 3 de 3
    • Use a flathead screwdriver or a prying tool, to unclip the main board cover.
    • Remove the main board cover.
  12. LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: paso 12, imagen 1 de 2 LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: paso 12, imagen 2 de 2
    • Remove the screw(s) securing the main board to the back side of the washer.
  13. LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: paso 13, imagen 1 de 3 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: paso 13, imagen 2 de 3 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: paso 13, imagen 3 de 3
    • Slide the main board out of its slot in the chassis.
  14. LG Front Load Washing Machine Main Board Replacement, Remove the main board: paso 14, imagen 1 de 3 LG Front Load Washing Machine Main Board Replacement, Remove the main board: paso 14, imagen 2 de 3 LG Front Load Washing Machine Main Board Replacement, Remove the main board: paso 14, imagen 3 de 3
    • Label each connector and its spot on the main board. During reassembly, reattach each connector to its proper spot.
    • Lift the main board out of the chassis to access each of the connectors.
    • Disconnect each connector from the main board.
    • Remove the main board.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
Bill Gilbert
Miembro Desde 06/30/22
38,494 Reputación
261 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
23,608 Guías creadas
1Guía Comentario
Thank you for the instructions. Can power to the front control panel be tested without connecting the pressure sensor and water lines.
albert - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 50
Ultimos 30 días: 176
Todo El Tiempo: 3,147
