Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LG Front Load Washing Machine Drain Filter Replacement
  1. LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: paso 1, imagen 1 de 2 LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: paso 1, imagen 2 de 2
    • Unclip the filter door from its slot in the chassis and let it rest on the ground.
  2. LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: paso 2, imagen 1 de 3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: paso 2, imagen 2 de 3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: paso 2, imagen 3 de 3
    • Place a bowl next to the device.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  3. LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: paso 3, imagen 1 de 3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: paso 3, imagen 2 de 3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: paso 3, imagen 3 de 3
    • Twist the drain filter counterclockwise until it's fully disconnected from the chassis.
    • Remove the drain filter.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Miembro Desde 06/30/22
38,781 Reputación
261 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
23,987 Guías creadas
2Guía Comentarios
I need to replace the clip door it fell off when we moved.
Maria Medina - Contestar
I need to replace that hose,it is clogged with sand. How do I get it in clipped.
Thanks, Kate
Kate Wolf - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 84
Ultimos 30 días: 293
Todo El Tiempo: 4,326
