Saltar al contenido principal
LG Front Load Washing Machine Air Dome Replacement
Qué necesitas
  1. LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: paso 1, imagen 1 de 2 LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: paso 1, imagen 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: paso 2, imagen 1 de 3 LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: paso 2, imagen 2 de 3 LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: paso 2, imagen 3 de 3
    • Remove the screw(s) securing the rear panel.
  3. LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: paso 3, imagen 1 de 3 LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: paso 3, imagen 2 de 3 LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: paso 3, imagen 3 de 3
    • Unclip the rear panel from the chassis.
  4. LG Front Load Washing Machine Air Dome Replacement: paso 4, imagen 1 de 1
    • Remove the rear panel.
  5. LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: paso 5, imagen 1 de 2 LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: paso 5, imagen 2 de 2
    • Pull the hose straight off the air dome hose to disconnect it.
  6. LG Front Load Washing Machine Air Dome Replacement, Unfasten the air dome: paso 6, imagen 1 de 1
    • Remove the screw(s) securing the air dome.
  7. LG Front Load Washing Machine Air Dome Replacement: paso 7, imagen 1 de 3 LG Front Load Washing Machine Air Dome Replacement: paso 7, imagen 2 de 3 LG Front Load Washing Machine Air Dome Replacement: paso 7, imagen 3 de 3
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
  8. LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: paso 8, imagen 1 de 2 LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: paso 8, imagen 2 de 2
    • Pull the air dome straight off its hose to remove it.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Miembro Desde 06/30/22
30,695 Reputación
213 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,895 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 66
Todo El Tiempo: 589
