Saltar al contenido principal
LG Fortune Motherboard Replacement
Qué necesitas
  1. LG Fortune Motherboard Replacement, Battery: paso 1, imagen 1 de 2 LG Fortune Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
  2. LG Fortune Motherboard Replacement: paso 2, imagen 1 de 2 LG Fortune Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
  3. LG Fortune Motherboard Replacement, Motherboard: paso 3, imagen 1 de 3 LG Fortune Motherboard Replacement, Motherboard: paso 3, imagen 2 de 3 LG Fortune Motherboard Replacement, Motherboard: paso 3, imagen 3 de 3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
  4. LG Fortune Motherboard Replacement: paso 4, imagen 1 de 1
    • Unplug the video card from the motherboard with a spudger or plastic opening tool.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
  5. LG Fortune Motherboard Replacement: paso 5, imagen 1 de 1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
  6. LG Fortune Motherboard Replacement: paso 6, imagen 1 de 1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
  7. LG Fortune Motherboard Replacement: paso 7, imagen 1 de 1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 564
