Saltar al contenido principal
LG Flare Microphone Replacement
Qué necesitas
  1. LG Flare Microphone Replacement, Microphone: paso 1, imagen 1 de 2 LG Flare Microphone Replacement, Microphone: paso 1, imagen 2 de 2
    • Remove the back cover by pressing on the top middle raised lines of the back cover and sliding the cover off.
  2. LG Flare Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the battery by popping the top out and removing the battery.
  3. LG Flare Microphone Replacement: paso 3, imagen 1 de 1
    • Use appropriately sized Philips-head screwdriver to remove the six small screws on the back of the phone under the battery.
  4. LG Flare Microphone Replacement: paso 4, imagen 1 de 1
    • Use an opening tool to pop the back panel apart around the edges, and then pry the whole piece off.
  5. LG Flare Microphone Replacement: paso 5, imagen 1 de 1
    • Use an opening tool to separate the tabs on the green circuit board from the front body of the phone.
  6. LG Flare Microphone Replacement: paso 6, imagen 1 de 1
    • Use an opening tool to pop the orange connecting strip off of the circuit board.
  7. LG Flare Microphone Replacement: paso 7, imagen 1 de 1
    • Un-clip the 2 metal clips on one side of the circuit board.
  8. LG Flare Microphone Replacement: paso 8, imagen 1 de 2 LG Flare Microphone Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers and wedge, remove silver piece from green circuit board.
  9. LG Flare Microphone Replacement: paso 9, imagen 1 de 1
    • Remove the microphone (rip soldering).
  10. LG Flare Microphone Replacement: paso 10, imagen 1 de 1
    • Solder new microphone in place OR buy replacement circuit board from www.ifixit.com and replace.
Conclusión
Kelsey Hanna
Miembro Desde 09/29/15
1 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-3, Garvin Fall 2015 Miembro de Ohio State, Team 1-3, Garvin Fall 2015
OSU-GARVIN-F15S1G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 186
