Saltar al contenido principal
LG Enact Screen Replacement
Qué necesitas
  1. LG Enact Screen Replacement, Battery: paso 1, imagen 1 de 3 LG Enact Screen Replacement, Battery: paso 1, imagen 2 de 3 LG Enact Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Screen Replacement: paso 2, imagen 1 de 3 LG Enact Screen Replacement: paso 2, imagen 2 de 3 LG Enact Screen Replacement: paso 2, imagen 3 de 3
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Screen Replacement, Speaker: paso 3, imagen 1 de 1
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Screen Replacement: paso 4, imagen 1 de 2 LG Enact Screen Replacement: paso 4, imagen 2 de 2
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Screen Replacement, Midframe: paso 5, imagen 1 de 2 LG Enact Screen Replacement, Midframe: paso 5, imagen 2 de 2
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Screen Replacement: paso 6, imagen 1 de 1
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Screen Replacement, Motherboard: paso 7, imagen 1 de 2 LG Enact Screen Replacement, Motherboard: paso 7, imagen 2 de 2
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Screen Replacement: paso 8, imagen 1 de 2 LG Enact Screen Replacement: paso 8, imagen 2 de 2
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Screen Replacement, Charging Port: paso 9, imagen 1 de 2 LG Enact Screen Replacement, Charging Port: paso 9, imagen 2 de 2
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
  10. LG Enact Screen Replacement, Keyboard: paso 10, imagen 1 de 3 LG Enact Screen Replacement, Keyboard: paso 10, imagen 2 de 3 LG Enact Screen Replacement, Keyboard: paso 10, imagen 3 de 3
    • Gently remove the blue metal plate using an iFixit opening pick.
    • Gently remove the black plastic from inside the battery compartment.
  11. LG Enact Screen Replacement: paso 11, imagen 1 de 1
    • Remove seven 1.2 mm screws with a Phillips #00 screwdriver.
  12. LG Enact Screen Replacement: paso 12, imagen 1 de 1
    • Remove the ribbon cable from the battery compartment.
  13. LG Enact Screen Replacement: paso 13, imagen 1 de 3 LG Enact Screen Replacement: paso 13, imagen 2 de 3 LG Enact Screen Replacement: paso 13, imagen 3 de 3
    • Remove the plastic half containing the keyboard.
  14. LG Enact Screen Replacement, Screen: paso 14, imagen 1 de 1
    • Remove the four 1.2 mm screws from the corners using a Phillips #00 screwdriver.
  15. LG Enact Screen Replacement: paso 15, imagen 1 de 2 LG Enact Screen Replacement: paso 15, imagen 2 de 2
    • Gently pry the screen open with a nylon spudger, making sure you’re not damaging the LCD or the plastic.
  16. LG Enact Screen Replacement: paso 16, imagen 1 de 2 LG Enact Screen Replacement: paso 16, imagen 2 de 2
    • Detach the two connectors from the screen and pop the screen open using a spudger.
  17. LG Enact Screen Replacement: paso 17, imagen 1 de 1
    • Disconnect the touch button sensors using a spudger.
  18. LG Enact Screen Replacement: paso 18, imagen 1 de 1
    • Gently disconnect and remove the LCD using a spudger.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 23
Todo El Tiempo: 114
