Introducción
A working charging port is a mandatory part of making sure your device works. If you are having issues with your LG Enact charging port not working properly, this guide will help you replace it.
Be sure the device is fully powered off and be sure to follow the steps correctly.
Qué necesitas
Open the back cover by prying into the bottom tab with an iFixit opening tool.
Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
Unplug the four ports connected to the motherboard.
Disconnect the two wires on top of the battery.
Disconnect the two wires under the battery.
Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
