Saltar al contenido principal
Introducción
The circuit board and full key board are attached and must be installed together as one unit. Do not try to separate them.
  1. Place the phone so the screen side is facing down.
    • Place the phone so the screen side is facing down.
    • Locate the latch at the end of the phone, opposite of the camera.
  2. Push/pull the latch away from the camera, causing the battery to pop out.
    • Push/pull the latch away from the camera, causing the battery to pop out.
  3. Remove the battery.
    • Remove the battery.
  4. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  5. Remove the 5 screw covers on the back of the phone using a Push Pin. Remove the 5 screw covers on the back of the phone using a Push Pin.
    • Remove the 5 screw covers on the back of the phone using a Push Pin.
  6. With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
  7. Open the phone. Open the phone.
    • Open the phone.
  8. Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work). Prying open the part just to the left of the right hinge can be difficult.
    • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
    • Prying open the part just to the left of the right hinge can be difficult.
    • Remove the back colored casing and set it to the side.
  9. Gently pry and detach the connection located near the hinge with fingers. Gently pry and detach the connection located near the hinge with fingers.
    • Gently pry and detach the connection located near the hinge with fingers.
  10. The circuit board and the key board will be attached, as shown in the second picture. Lift them both out from the rest of the phone.
    • The circuit board and the key board will be attached, as shown in the second picture.
    • Lift them both out from the rest of the phone.
    • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
Conclusión
Equipo
Cal Poly, Team 15-15, Forte Spring 2012 Miembro de Cal Poly, Team 15-15, Forte Spring 2012
CPSU-FORTE-S12S15G15
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 1,094
