Saltar al contenido principal
LG EnV Touch VX11000 Motherboard Replacement
Qué necesitas
  1. LG EnV Touch VX11000 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Motherboard Replacement: paso 2, imagen 1 de 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Motherboard Replacement: paso 3, imagen 1 de 2 LG EnV Touch VX11000 Motherboard Replacement: paso 3, imagen 2 de 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Motherboard Replacement, Volume and Camera Buttons: paso 4, imagen 1 de 2 LG EnV Touch VX11000 Motherboard Replacement, Volume and Camera Buttons: paso 4, imagen 2 de 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Motherboard Replacement: paso 5, imagen 1 de 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Motherboard Replacement: paso 6, imagen 1 de 2 LG EnV Touch VX11000 Motherboard Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 LG EnV Touch VX11000 Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Use your fingers to pull up on the tab in order to unplug it.
  8. LG EnV Touch VX11000 Motherboard Replacement: paso 8, imagen 1 de 2 LG EnV Touch VX11000 Motherboard Replacement: paso 8, imagen 2 de 2
    • Using both of your hands, gently pry out the motherboard by pulling up on both ends.
Conclusión
3 personas más completaron esta guía.
Rachel Smith
Miembro Desde 09/30/13
593 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-2, Forte Fall 2013 Miembro de Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 546
