Introducción
If your LG EnV Touch VX11000 shuts down unexpectedly or the screen is broken or malfunctioning, you may need to replace the motherboard. This guide will show you how to replace the motherboard in an LG EnV Touch VX11000.
Qué necesitas
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
3 personas más completaron esta guía.
