Saltar al contenido principal
LG Dare Logic Board Replacement
Qué necesitas
  1. LG Dare Logic Board Replacement, Battery: paso 1, imagen 1 de 2 LG Dare Logic Board Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. LG Dare Logic Board Replacement: paso 2, imagen 1 de 3 LG Dare Logic Board Replacement: paso 2, imagen 2 de 3 LG Dare Logic Board Replacement: paso 2, imagen 3 de 3
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. LG Dare Logic Board Replacement, Logic Board: paso 3, imagen 1 de 2 LG Dare Logic Board Replacement, Logic Board: paso 3, imagen 2 de 2
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. LG Dare Logic Board Replacement: paso 4, imagen 1 de 3 LG Dare Logic Board Replacement: paso 4, imagen 2 de 3 LG Dare Logic Board Replacement: paso 4, imagen 3 de 3
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. LG Dare Logic Board Replacement: paso 5, imagen 1 de 3 LG Dare Logic Board Replacement: paso 5, imagen 2 de 3 LG Dare Logic Board Replacement: paso 5, imagen 3 de 3
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. LG Dare Logic Board Replacement: paso 6, imagen 1 de 1
    • Disconnect the three ribbon connectors from the motherboard.
  7. LG Dare Logic Board Replacement: paso 7, imagen 1 de 3 LG Dare Logic Board Replacement: paso 7, imagen 2 de 3 LG Dare Logic Board Replacement: paso 7, imagen 3 de 3
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. LG Dare Logic Board Replacement: paso 8, imagen 1 de 1
    • Open the USB port cover.
  9. LG Dare Logic Board Replacement: paso 9, imagen 1 de 3 LG Dare Logic Board Replacement: paso 9, imagen 2 de 3 LG Dare Logic Board Replacement: paso 9, imagen 3 de 3
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
Conclusión
To re-assemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
Haoyan Huang
Miembro Desde 01/26/12
139 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-4, Regan Winter 2012 Miembro de Cal Poly, Team 9-4, Regan Winter 2012
CPSU-REGAN-W12S9G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,159
