1. Insert the plastic opener into the slot at the top of the device. Apply gentle pressure with the plastic tool to pop the back case off. Apply gentle pressure with the plastic tool to pop the back case off.
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery.
    • Use the plastic opener to lift, and remove, the device battery.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  5. Use the plastic opener to pry the rear case loose. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  6. Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker. Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
    • Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
Conclusión
Nick White
Miembro Desde 18/10/13
827 Reputación
8 Guías creadas
Equipo
Clemson, Team 13-1, Benson Fall 2013 Miembro de Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 228
