Saltar al contenido principal
LG Cosmos 2 Rear Case Replacement
Qué necesitas
  1. LG Cosmos 2 Rear Case Replacement, Battery: paso 1, imagen 1 de 3 LG Cosmos 2 Rear Case Replacement, Battery: paso 1, imagen 2 de 3 LG Cosmos 2 Rear Case Replacement, Battery: paso 1, imagen 3 de 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Rear Case Replacement: paso 2, imagen 1 de 3 LG Cosmos 2 Rear Case Replacement: paso 2, imagen 2 de 3 LG Cosmos 2 Rear Case Replacement: paso 2, imagen 3 de 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Rear Case Replacement, Rear Case: paso 3, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Rear Case Replacement: paso 4, imagen 1 de 3 LG Cosmos 2 Rear Case Replacement: paso 4, imagen 2 de 3 LG Cosmos 2 Rear Case Replacement: paso 4, imagen 3 de 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
Conclusión
Nick White
Miembro Desde 10/18/13
866 Reputación
8 Guías creadas
Equipo
Clemson, Team 13-1, Benson Fall 2013 Miembro de Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 296
