Saltar al contenido principal
LG Cosmos 2 Motherboard Replacement
Qué necesitas
  1. LG Cosmos 2 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 LG Cosmos 2 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 LG Cosmos 2 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Motherboard Replacement: paso 2, imagen 1 de 3 LG Cosmos 2 Motherboard Replacement: paso 2, imagen 2 de 3 LG Cosmos 2 Motherboard Replacement: paso 2, imagen 3 de 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Motherboard Replacement, Rear Case: paso 3, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Motherboard Replacement: paso 4, imagen 1 de 3 LG Cosmos 2 Motherboard Replacement: paso 4, imagen 2 de 3 LG Cosmos 2 Motherboard Replacement: paso 4, imagen 3 de 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 Motherboard Replacement: paso 6, imagen 1 de 1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 Motherboard Replacement: paso 7, imagen 1 de 2 LG Cosmos 2 Motherboard Replacement: paso 7, imagen 2 de 2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 Motherboard Replacement: paso 8, imagen 1 de 2 LG Cosmos 2 Motherboard Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard from the front case.
Conclusión
Nick White
Miembro Desde 10/18/13
851 Reputación
8 Guías creadas
Equipo
Clemson, Team 13-1, Benson Fall 2013 Miembro de Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,135
