Saltar al contenido principal
LG Cosmos 2 LCD Display Replacement
Qué necesitas
  1. LG Cosmos 2 LCD Display Replacement, Battery: paso 1, imagen 1 de 3 LG Cosmos 2 LCD Display Replacement, Battery: paso 1, imagen 2 de 3 LG Cosmos 2 LCD Display Replacement, Battery: paso 1, imagen 3 de 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 LCD Display Replacement: paso 2, imagen 1 de 3 LG Cosmos 2 LCD Display Replacement: paso 2, imagen 2 de 3 LG Cosmos 2 LCD Display Replacement: paso 2, imagen 3 de 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 LCD Display Replacement, Rear Case: paso 3, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 LCD Display Replacement: paso 4, imagen 1 de 3 LG Cosmos 2 LCD Display Replacement: paso 4, imagen 2 de 3 LG Cosmos 2 LCD Display Replacement: paso 4, imagen 3 de 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 LCD Display Replacement, Motherboard: paso 5, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 LCD Display Replacement: paso 6, imagen 1 de 1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 LCD Display Replacement: paso 7, imagen 1 de 2 LG Cosmos 2 LCD Display Replacement: paso 7, imagen 2 de 2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 LCD Display Replacement: paso 8, imagen 1 de 2 LG Cosmos 2 LCD Display Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 LCD Display Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 LCD Display Replacement, Option Buttons: paso 10, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 LCD Display Replacement: paso 11, imagen 1 de 2 LG Cosmos 2 LCD Display Replacement: paso 11, imagen 2 de 2
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 LCD Display Replacement: paso 12, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 LCD Display Replacement: paso 13, imagen 1 de 2 LG Cosmos 2 LCD Display Replacement: paso 13, imagen 2 de 2
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 LCD Display Replacement: paso 14, imagen 1 de 1
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 LCD Display Replacement: paso 15, imagen 1 de 1
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 LCD Display Replacement: paso 16, imagen 1 de 3 LG Cosmos 2 LCD Display Replacement: paso 16, imagen 2 de 3 LG Cosmos 2 LCD Display Replacement: paso 16, imagen 3 de 3
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 LCD Display Replacement: paso 17, imagen 1 de 1
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
  18. LG Cosmos 2 LCD Display Replacement, LCD Display: paso 18, imagen 1 de 2 LG Cosmos 2 LCD Display Replacement, LCD Display: paso 18, imagen 2 de 2
    • Use a tool to pry open the LCD display. Remove the display and the circuit board that it's connected to.
  19. LG Cosmos 2 LCD Display Replacement: paso 19, imagen 1 de 1
    Comprar
    • Remove the plastic piece from the circuit board by unlocking the switch on the plastic piece with a pair of tweezers.
  20. LG Cosmos 2 LCD Display Replacement: paso 20, imagen 1 de 1
    • Using a pair of tweezers, remove the tape.
  21. LG Cosmos 2 LCD Display Replacement: paso 21, imagen 1 de 1
    • Using either your finger or the plastic opener, disconnect the cable.
  22. LG Cosmos 2 LCD Display Replacement: paso 22, imagen 1 de 2 LG Cosmos 2 LCD Display Replacement: paso 22, imagen 2 de 2
    • Pull the LCD display away from the circuit board.
    • You shouldn't feel any resistance. If you notice resistance, make sure you have completed the previous step.
Conclusión
Una persona más ha completado esta guía.
Nick White
Miembro Desde 10/18/13
851 Reputación
8 Guías creadas
Equipo
Clemson, Team 13-1, Benson Fall 2013 Miembro de Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 2,461
