Introducción
We will teach you how to effectively and safely disassemble the LG Cosmos 2, replace the headphone jack, and just as effectively and safely reassemble the device. You will not need any special materials, just a screwdriver, and your hands/a spudger.
Qué necesitas
First you will need to remove the back cover of the device.
You can do this with either a spudger or your fingers.
Carefully pry along the edges of the device until the cover pops off.
Herramienta utilizada en este paso:Desoldering Pump$3.99
Carefully use a soldering iron to heat the bolts and then use a desoldering pump to pull the bolts out.
Then simply lift out the old headphone jack and fit in the new one.
