Qué necesitas
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
Use a tool to pry open the LCD display. Remove the display and the motherboard-looking device that it's connected to.
