Saltar al contenido principal
LG CineBeam Speaker Replacement
Qué necesitas
  1. LG CineBeam Speaker Replacement, Bottom Plate: paso 1, imagen 1 de 1
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
  2. LG CineBeam Speaker Replacement: paso 2, imagen 1 de 3 LG CineBeam Speaker Replacement: paso 2, imagen 2 de 3 LG CineBeam Speaker Replacement: paso 2, imagen 3 de 3
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
  3. LG CineBeam Speaker Replacement, Motherboard: paso 3, imagen 1 de 3 LG CineBeam Speaker Replacement, Motherboard: paso 3, imagen 2 de 3 LG CineBeam Speaker Replacement, Motherboard: paso 3, imagen 3 de 3
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
  4. LG CineBeam Speaker Replacement: paso 4, imagen 1 de 2 LG CineBeam Speaker Replacement: paso 4, imagen 2 de 2
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
  5. LG CineBeam Speaker Replacement: paso 5, imagen 1 de 3 LG CineBeam Speaker Replacement: paso 5, imagen 2 de 3 LG CineBeam Speaker Replacement: paso 5, imagen 3 de 3
    • Lift the motherboard out of the casing.
  6. LG CineBeam Speaker Replacement, Speaker: paso 6, imagen 1 de 2 LG CineBeam Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Use your fingers to lift the speaker from the casing.
Conclusión
Abid Neron
Miembro Desde 03/23/22
243 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 74
