Saltar al contenido principal
LG Chocolate Touch Buttons Replacement
Qué necesitas
  1. LG Chocolate Touch Buttons Replacement, Battery: paso 1, imagen 1 de 2 LG Chocolate Touch Buttons Replacement, Battery: paso 1, imagen 2 de 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Touch Buttons Replacement, Back Cover: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Touch Buttons Replacement: paso 3, imagen 1 de 3 LG Chocolate Touch Buttons Replacement: paso 3, imagen 2 de 3 LG Chocolate Touch Buttons Replacement: paso 3, imagen 3 de 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Touch Buttons Replacement, Sliding Front: paso 4, imagen 1 de 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Touch Buttons Replacement: paso 5, imagen 1 de 2 LG Chocolate Touch Buttons Replacement: paso 5, imagen 2 de 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Touch Buttons Replacement: paso 6, imagen 1 de 2 LG Chocolate Touch Buttons Replacement: paso 6, imagen 2 de 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Touch Buttons Replacement: paso 7, imagen 1 de 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Touch Buttons Replacement, LCD Board: paso 8, imagen 1 de 3 LG Chocolate Touch Buttons Replacement, LCD Board: paso 8, imagen 2 de 3 LG Chocolate Touch Buttons Replacement, LCD Board: paso 8, imagen 3 de 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Touch Buttons Replacement: paso 9, imagen 1 de 2 LG Chocolate Touch Buttons Replacement: paso 9, imagen 2 de 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Touch Buttons Replacement: paso 10, imagen 1 de 1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Touch Buttons Replacement: paso 11, imagen 1 de 1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Touch Buttons Replacement: paso 12, imagen 1 de 2 LG Chocolate Touch Buttons Replacement: paso 12, imagen 2 de 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Touch Buttons Replacement, Touch Buttons: paso 13, imagen 1 de 1
    • Using a flat head screwdriver, pry the plastic covering off of the back of the keypad
  14. LG Chocolate Touch Buttons Replacement: paso 14, imagen 1 de 2 LG Chocolate Touch Buttons Replacement: paso 14, imagen 2 de 2
    • Push the keypad from behind to disconnect it from the case.
Conclusión
2 personas más completaron esta guía.
Thomas
Miembro Desde 01/18/13
91 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 19-46, Regan Winter 2013 Miembro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 375
