Saltar al contenido principal
LG Chocolate Keypad Replacement
Qué necesitas
  1. LG Chocolate Keypad Replacement, Battery: paso 1, imagen 1 de 2 LG Chocolate Keypad Replacement, Battery: paso 1, imagen 2 de 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Keypad Replacement, Back Cover: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Keypad Replacement: paso 3, imagen 1 de 3 LG Chocolate Keypad Replacement: paso 3, imagen 2 de 3 LG Chocolate Keypad Replacement: paso 3, imagen 3 de 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Keypad Replacement, Sliding Front: paso 4, imagen 1 de 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Keypad Replacement: paso 5, imagen 1 de 2 LG Chocolate Keypad Replacement: paso 5, imagen 2 de 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Keypad Replacement: paso 6, imagen 1 de 2 LG Chocolate Keypad Replacement: paso 6, imagen 2 de 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Keypad Replacement: paso 7, imagen 1 de 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Keypad Replacement, LCD Board: paso 8, imagen 1 de 3 LG Chocolate Keypad Replacement, LCD Board: paso 8, imagen 2 de 3 LG Chocolate Keypad Replacement, LCD Board: paso 8, imagen 3 de 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Keypad Replacement: paso 9, imagen 1 de 2 LG Chocolate Keypad Replacement: paso 9, imagen 2 de 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Keypad Replacement: paso 10, imagen 1 de 1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Keypad Replacement: paso 11, imagen 1 de 1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Keypad Replacement: paso 12, imagen 1 de 2 LG Chocolate Keypad Replacement: paso 12, imagen 2 de 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Keypad Replacement, LCD Screen: paso 13, imagen 1 de 1
    • The LCD screen is no longer connected to the LCD board.
  14. LG Chocolate Keypad Replacement, Keypad: paso 14, imagen 1 de 1
    • Push the keypad out from the front of the phone and remove it.
Conclusión
Maci Miri
Miembro Desde 01/18/13
39 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-46, Regan Winter 2013 Miembro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 324
