Introducción
Use this guide to replace the damaged or cracked rear case of your LG Chocolate 3. You may just need to access the internals of your phone to do other work and this guide will help you do that too. Be prepared to manage small screws.
Qué necesitas
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
