Saltar al contenido principal
LG Chocolate 3 Rear Case Replacement
Qué necesitas
  1. LG Chocolate 3 Rear Case Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
  2. LG Chocolate 3 Rear Case Replacement: paso 2, imagen 1 de 3 LG Chocolate 3 Rear Case Replacement: paso 2, imagen 2 de 3 LG Chocolate 3 Rear Case Replacement: paso 2, imagen 3 de 3
    • Using your index finger lift and remove the battery from the phone.
  3. LG Chocolate 3 Rear Case Replacement, Rear Case: paso 3, imagen 1 de 1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
  4. LG Chocolate 3 Rear Case Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
  5. LG Chocolate 3 Rear Case Replacement: paso 5, imagen 1 de 2 LG Chocolate 3 Rear Case Replacement: paso 5, imagen 2 de 2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
  6. LG Chocolate 3 Rear Case Replacement: paso 6, imagen 1 de 1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  7. LG Chocolate 3 Rear Case Replacement: paso 7, imagen 1 de 2 LG Chocolate 3 Rear Case Replacement: paso 7, imagen 2 de 2
    • Carefully remove the rear case from the phone.
Conclusión
Equipo
Cal Poly, Team 12-35, Amido Spring 2013 Miembro de Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 295
