Saltar al contenido principal
LG Chocolate 3 Front Faceplate Replacement
Qué necesitas
  1. LG Chocolate 3 Front Faceplate Replacement, Front Faceplate: paso 1, imagen 1 de 1
    • Use the plastic opening tool to lift the front faceplate from the device.
    • The faceplate has adhesive in multiple areas. Loosen the faceplate around all of the edges first to make it easier to remove.
  2. LG Chocolate 3 Front Faceplate Replacement: paso 2, imagen 1 de 1
    • The scroll wheel has an orange display data cable attached which may rip from excessive force.
    • Lift the front faceplate up gently.
  3. LG Chocolate 3 Front Faceplate Replacement: paso 3, imagen 1 de 1
    • Be careful not to rip the orange display data cable or drop the scroll wheel on the LCD screen.
    • Use the flat end of the spudger to pry the scroll wheel from the faceplate.
  4. LG Chocolate 3 Front Faceplate Replacement: paso 4, imagen 1 de 2 LG Chocolate 3 Front Faceplate Replacement: paso 4, imagen 2 de 2
    • Separate the front faceplate from the device completely.
Conclusión
Una persona más ha completado esta guía.
Brenna Yagade
Miembro Desde 04/15/13
40 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-35, Amido Spring 2013 Miembro de Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 303
