Saltar al contenido principal
LG CU515 SKU 64743 Device SIM Card Replacement
Qué necesitas
  1. LG CU515 SKU 64743 Device SIM Card Replacement, Back Cover: paso 1, imagen 1 de 3 LG CU515 SKU 64743 Device SIM Card Replacement, Back Cover: paso 1, imagen 2 de 3 LG CU515 SKU 64743 Device SIM Card Replacement, Back Cover: paso 1, imagen 3 de 3
    • Locate the raised tab at the top of the back cover.
    • Holding the phone in one hand and using your thumb on your other hand, push down on the tab until the cover detaches from the phone.
    • Slide the cover down until it is completely removed from the phone.
  2. Aviso: el paso 2 proviene de una guía que está marcada como "En progreso".
    LG CU515 SKU 64743 Device SIM Card Replacement, Battery: paso 2, imagen 1 de 3 LG CU515 SKU 64743 Device SIM Card Replacement, Battery: paso 2, imagen 2 de 3 LG CU515 SKU 64743 Device SIM Card Replacement, Battery: paso 2, imagen 3 de 3
    • Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone.
  3. LG CU515 SKU 64743 Device SIM Card Replacement, SIM Card: paso 3, imagen 1 de 3 LG CU515 SKU 64743 Device SIM Card Replacement, SIM Card: paso 3, imagen 2 de 3 LG CU515 SKU 64743 Device SIM Card Replacement, SIM Card: paso 3, imagen 3 de 3
    • Holding the phone in one hand and using your thumb on your other hand, push the SIM card towards the bottom of the phone and out from under the metal retaining clip holding it in place. It should slide out relatively easy.
Conclusión
Josh Davis
Miembro Desde 10/18/13
301 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 349
