Saltar al contenido principal
LG CU515 Motherboard Replacement
Qué necesitas
  1. LG CU515 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 LG CU515 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Motherboard Replacement: paso 2, imagen 1 de 3 LG CU515 Motherboard Replacement: paso 2, imagen 2 de 3 LG CU515 Motherboard Replacement: paso 2, imagen 3 de 3
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Motherboard Replacement: paso 5, imagen 1 de 3 LG CU515 Motherboard Replacement: paso 5, imagen 2 de 3 LG CU515 Motherboard Replacement: paso 5, imagen 3 de 3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Motherboard Replacement: paso 8, imagen 1 de 1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
Conclusión
Zack Mintzer
Miembro Desde 04/16/13
1 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-55, Johann Spring 2013 Miembro de Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 339
