Saltar al contenido principal
LG CG225 Keyboard Replacement
Qué necesitas
  1. LG CG225 Keyboard Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Keyboard Replacement: paso 3, imagen 1 de 1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Keyboard Replacement, Motherboard: paso 4, imagen 1 de 1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Keyboard Replacement: paso 5, imagen 1 de 1
    • Using a small plastic opening tool, remove the motherboard.
  6. LG CG225 Keyboard Replacement, Keyboard: paso 6, imagen 1 de 1
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
Conclusión
Mackenzie
Miembro Desde 02/13/14
1 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-3, Meza Spring 2014 Miembro de Ohio State, Team 1-3, Meza Spring 2014
OSU-MEZA-S14S1G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 274
