Saltar al contenido principal
LG CF360 Back Cover Replacement
Qué necesitas
  1. LG CF360 Back Cover Replacement, Battery: paso 1, imagen 1 de 2 LG CF360 Back Cover Replacement, Battery: paso 1, imagen 2 de 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Back Cover Replacement: paso 2, imagen 1 de 1
    • Lift and remove the battery.
  3. LG CF360 Back Cover Replacement, Back Cover: paso 3, imagen 1 de 2 LG CF360 Back Cover Replacement, Back Cover: paso 3, imagen 2 de 2
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Back Cover Replacement: paso 4, imagen 1 de 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Back Cover Replacement: paso 5, imagen 1 de 3 LG CF360 Back Cover Replacement: paso 5, imagen 2 de 3 LG CF360 Back Cover Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Back Cover Replacement: paso 6, imagen 1 de 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
Conclusión
Equipo
Cal Poly, Team 4-27, Amido Fall 2013 Miembro de Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Miembros
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 294
